[gdal-dev] Why are vertices slightly different when writing and rereading geomtries using OgrInfo and Esri.FileGDBAPI
Wiss, Benno (Softec) Benno.Wiss at softec.ch
Tue Mar 28 00:53:40 PDT 2017
Using the C# GDAL FileGDB API V 1.5 (https://trac.osgeo.org/gdal/wiki/FileGDB) I have written a simple test application which writes and rereads a polygon geometry. The  test FileGDB is using WKID 21781 (CH1903_LV03), XYScale of 20'000 and  XYTolerance of 0.0004.
Using the test application I have written a polygon with the following coordinates
    POLYGON((
    660440.402                232655.598,
    660419.723456789  232646.789153456,
    660398.588123         232712.410135,
    660477.806                232751.485, ...))
Reading the polygon using OgrInfo gets following coordinates
    MULTIPOLYGON (((
    660419.723450001  232646.78915,
    660398.588100001  232712.410149999,
    660477.806                232751.485, ...)))"
Rereading the geometry using the C# Esri.FileGDBAPI gets following coordinates
    point[0]  660440.40199999884   232655.59800000116
    point[1]  660419.72345000133   232646.78914999962
    point[2]  660398.58810000122   232712.41014999896
    point[3]  660477.80600000173   232751.4849999994
Regarding the XYScale of 20'000 it is correct that the position 660398.588123 is altered to 660398.58810.  But considering the value of 660398.588100001 the coordinates seems not to be stored as whole numbers.
Using the Esri.FileGDBAPI the values differ even more. It seems to be a floating point accuracy problem but I don't really understand why. How are the coordinates stored in FileGDB and why does the read values differ between OgrInfo and Esri.FileGDBAPI?
Thanks in anticipation
Benno Wiss
