[gdal-dev] Why are vertices slightly different when writing and rereading geomtries using OgrInfo and Esri.FileGDBAPI
Even Rouault even.rouault at spatialys.com
Tue Mar 28 04:38:28 PDT 2017
On mardi 28 mars 2017 09:53:40 CEST Wiss, Benno (Softec) wrote:
> Hi,
> Using the C# GDAL FileGDB API V 1.5
> (https://trac.osgeo.org/gdal/wiki/FileGDB) I have written a simple test
> application which writes and rereads a polygon geometry. The  test FileGDB
> is using WKID 21781 (CH1903_LV03), XYScale of 20'000 and  XYTolerance of
> 0.0004. Using the test application I have written a polygon with the
> following coordinates POLYGON((
>     660440.402                232655.598,
>     660419.723456789  232646.789153456,
>     660398.588123         232712.410135,
>     660477.806                232751.485, ...))
> Reading the polygon using OgrInfo gets following coordinates
>     MULTIPOLYGON (((
>     660419.723450001  232646.78915,
>     660398.588100001  232712.410149999,
>     660477.806                232751.485, ...)))"
> Rereading the geometry using the C# Esri.FileGDBAPI gets following
> coordinates point[0]  660440.40199999884   232655.59800000116
>     point[1]  660419.72345000133   232646.78914999962
>     point[2]  660398.58810000122   232712.41014999896
>     point[3]  660477.80600000173   232751.4849999994
> Regarding the XYScale of 20'000 it is correct that the position
> 660398.588123 is altered to 660398.58810.  But considering the value of
> 660398.588100001 the coordinates seems not to be stored as whole numbers.
They are *stored* as whole numbers, but then they are scaled to real numbers who have no
exact decimal representations. In OGR coordinates are stored as 64 bit IEEE754 floating
point values. And then printed to decimal with an arbitrary number of decimal that doesn't
take into account the FileGDB precision.
> Using the Esri.FileGDBAPI the values differ even more. It seems to be a
> floating point accuracy problem but I don't really understand why.
Probably just a difference in the formatting of the output
> How are
> the coordinates stored in FileGDB and why does the read values differ
> between OgrInfo and Esri.FileGDBAPI?
> Thanks in anticipation
> Benno Wiss
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170328/b445e409/attachment.html>
