[gdal-dev] Building GDAL on linux with minimal drivers
Kurt Schwehr
schwehr at gmail.com
Thu Mar 30 07:34:35 PDT 2017
Some possibly useful notes...
I use bazel for a restricted build. Here are a few key files/directories
that I've found to be in surprising places that are hard or impossible to
go without:
frmts/gtiff/
frmts/hfa/hfa_overviews.cpp
frmts/iso8211/
frmts/mem/memdataset.cpp
frmts/pds/nasakeywordhandler.cpp
frmts/raw/rawdataset.cpp
frmts/vrt/
ogr/ogrsf_frmts/generic/
ogr/ogrsf_frmts/geojson/
ogr/ogrsf_frmts/gml/
ogr/ogrsf_frmts/mem/
ogr/ogrsf_frmts/mitab/ (except mitab_ogr*)
ogr/ogrsf_frmts/vrt/
ogr/ogrsf_frmts/xplane/ogr_xplane_geo_utils.cpp
The gtiff, mem (raster and vector), and vrt (raster and vector) directories
aren't really surprising after you see that it's hard to do a lot of things
without them as helpers. If you look in the format registration code, you
will see there are a lot of drivers that depend on others.
I also add these cpp defines for my non-autoconf setup:
-DWITHOUT_CPLDEBUG
-DDISABLE_CVSID
-DGDAL_NO_AUTOLOAD
At one point, I had a autoconf configure setup that was pretty minimal.
While it built, it was not so much fun to work with. Here are some
remnants of notes that might constitute the beginnings of a
sourceme-minimal.sh. More will likely be needed depending on libs are
already installed on your machine. And gdal without many of these libs
(e.g. proj4, geos, libz/zlib) is just frustrating.
Maybe we need a section to
https://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers that is
a stab at what the mimumum to build is without respect to if it's actually
useful for anything beyond testing purposes. e.g. I have a build target
that is just a subset of port that I use with the autotest2 port tests. It
makes linking and analysis go a lot faster when you don't have anything
beyond port in the build.
And it's been a long time since I've tried the optimize for size flag in
gcc or llvm (-g0 -Os)...
-kurt
#!/bin/bash
echo "Totally untested."
echo "See ./configure --help | egrep 'enable|disable|yes|no|with' "
GDAL_OPTS=""
# Languages
GDAL_OPTS="$GDAL_OPTS --without-python"
# Compilation options
GDAL_OPTS="$GDAL_OPTS --without-avx"
GDAL_OPTS="$GDAL_OPTS --without-sse"
# --without-pam
# Library options
GDAL_OPTS="$GDAL_OPTS --with-cryptopp=no"
GDAL_OPTS="$GDAL_OPTS --without-curl"
GDAL_OPTS="$GDAL_OPTS --without-expat"
GDAL_OPTS="$GDAL_OPTS --without-geos"
GDAL_OPTS="$GDAL_OPTS --with-odbc=no"
GDAL_OPTS="$GDAL_OPTS --without-odbc"
GDAL_OPTS="$GDAL_OPTS --without-pcre"
GDAL_OPTS="$GDAL_OPTS --without-qhull"
GDAL_OPTS="$GDAL_OPTS --without-sqlite3" # You're not going to want to do
this if you want gpkg!
GDAL_OPTS="$GDAL_OPTS --with-xerces=no"
GDAL_OPTS="$GDAL_OPTS --without-xml2"
GDAL_OPTS="$GDAL_OPTS --with-libz=no"
GDAL_OPTS="$GDAL_OPTS --with-liblzma=no"
# Driver options
# TODO: Put lots of driver withouts here.
# TODO: Disable debugging and define NDEBUG
# TODO: Disable alg and apps that you don't use
echo ./configure $GDAL_OPTS
On Thu, Mar 30, 2017 at 3:06 AM, Dmitry Baryshnikov <bishop.dev at gmail.com>
wrote:
> Hi Gane,
> You can try to use Cmake build of GDAL (https://github.com/nextgis-
> borsch/lib_gdal).
> It can be configured via CMake-gui or command line.
> This is an example of minimal static build of GDAL -
> https://github.com/nextgis/nextgis_datastore/blob/master/
> cmake/extlib.cmake#L94-L175
> Best regards,
> Dmitry
> 29.03.17 12:17, Gane R пишет:
> Hi all,
> I am looking for building gdal with minimal set of drivers like gdal with
> geotiff, jpg, png and sqlite gpkg
> so it should do basic warp geotiff and work with geopkg raster. I don't
> need OGR part I need the core, alg and raster tif, gpkg, jpg and png alone
> is enought.
> the problem is I get a fat static lib. I want to reduce its size.
> I tried to follow the post https://trac.osgeo.org/gdal/wiki/
> BuildingOnUnixWithMinimizedDrivers It seems it is old.
> When I build i get error during building the apps like gdalinfo, gdalwarp
> Any suggestions
> my ogr/ogrsf_frmts/GNUmakefile is
> like
> include ../../GDALmake.opt
> SUBDIRS-yes := \
> generic rec shape
> SUBDIRS-$(HAVE_DODS) += dods
> SUBDIRS-$(HAVE_DWGDIRECT) += dxfdwg
> SUBDIRS-$(HAVE_FME) += fme
> SUBDIRS-$(HAVE_GRASS) += grass
> SUBDIRS-$(HAVE_IDB) += idb
> I get the following error
> /home/user/home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference
> to `TABINDFile::~TABINDFile()'
> to `TABINDFile::FindNext(int, unsigned char*)'
> /home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference to
> `gdal_json_object_object_add'
> `TABINDFile::Open(char const, char const, int)'
> `OGRMemLayer::CreateField(OGRFieldDefn*, int)'
> `gdal_json_object_to_file'
> `MITABSpatialRef2CoordSys(OGRSpatialReference*)'
> `gdal_json_tokener_free'
> `gdal_json_object_new_int64'
> `gdal_json_object_get_string'
> `OGRMemLayer::GetFeatureCount(int)'
> `TABINDFile::BuildKey(int, int)'
> `gdal_json_object_array_add'
> `gdal_json_object_new_object'
> `OGRXPlane_ExtendPosition(double, double, double, double, double*,
> double*)'
> `OGRMemLayer::SetNextByIndex(long long)'
> `OGRMemLayer::CreateGeomField(OGRGeomFieldDefn*, int)'
> `OGRMemLayer::ResetReading()'
> `OGRMemLayer::ICreateFeature(OGRFeature*)'
> `OGRXPlane_Distance(double, double, double, double)'
> `TABINDFile::AddEntry(int, unsigned char*, int)'
> `gdal_json_object_put'
> `json_object_new_double_with_precision'
> `OGRMemLayer::TestCapability(char const*)'
> `OGRMemLayer::DeleteFeature(long long)'
> `gdal_json_object_new_int'
> `TABINDFile::Close()'
> `gdal_json_object_get_type'
> `OGRMemLayer::GetNextFeature()'
> `OGRMemLayer::OGRMemLayer(char const, OGRSpatialReference,
> OGRwkbGeometryType)'
> `TABINDFile::BuildKey(int, char const*)'
> `gdal_json_object_from_file'
> Thanks
> Gane
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170330/68c0312c/attachment-0001.html>
