[gdal-dev] Building GDAL on linux with minimal drivers
Even Rouault
even.rouault at spatialys.com
Thu Mar 30 07:48:51 PDT 2017
On jeudi 30 mars 2017 07:34:35 CEST Kurt Schwehr wrote:
> At one point, I had a autoconf configure setup that was pretty minimal.
> While it built, it was not so much fun to work with. Here are some
> remnants of notes that might constitute the beginnings of a
> sourceme-minimal.sh. More will likely be needed depending on libs are
> already installed on your machine. And gdal without many of these libs
> (e.g. proj4, geos, libz/zlib) is just frustrating.
As it seems several people have needs for minimized builds, perhaps they should consider
upstreaming their efforts with build options (like --minimal and then --with-XXXX to
selectively enable drivers), and the potential code refactoring that might make it easy. I
think a continuous integration target that would test that would be needed to ensure this
doesn't get broken by later developments.
Of course one difficulty is to define what a minimal build is :-)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170330/8b628eba/attachment.html>
