[gdal-dev] Automating code style enforcement ?
Even Rouault even.rouault at spatialys.com
Fri May 5 00:22:04 PDT 2017
Hi Mateusz,
> Please, let's forget about astyle.
Because you consider it more limited feature-wise than clang-format ?
(https://trac.osgeo.org/geos/wiki/RFC4 : "wrapping long lines whether of code, strings,
arrays - something which AStyle has no way of doing")
I'm wondering what you mean by "No automation of code reformatting is proposed. It would
be treating the symptomps, no cause: developers not following the code formatting
standard. "
I'd really want a script to fix edited files and fix them. From a quick look, it isn't obvious that
my favorite text editor (kate) could ingest a .clang-format file to enforce the style when I'm
editing. And honestly I don't even want to learn the rules of the style we would apply. We
*need* something to fix it easily like scripts/prepare-commit[.sh/.py] that will check svn/git
edited files and run them through the reformatter.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170505/8af9aaf4/attachment.html>
