[gdal-dev] WMTS "No zoom level found"
Hugues François
hugues.francois at irstea.fr
Fri May 5 11:09:17 PDT 2017
Sorry, it took me sometimes to answer. I don't know what happenned with the copy/paste from terminal but the url was truncated.
However, it ran the gdalinfo with the right layer name and it is after this text.
Regards,
Hug
gdalinfo "WMTS:http://wxs.ign.fr/an7nvfzojv5wa96dsga5nk8w/geoportail/wmts?SERVICE=WMTS&REQUEST=GetCapabilities,layer=GEOGRAPHICALGRIDSYSTEMS.MAPS.SCAN-EXPRESS.STANDARD"
Driver: WMTS/OGC Web Mab Tile Service
Files: none associated
Size is 7168, 7835
Coordinate System is:
PROJCS["WGS 84 / Pseudo-Mercator",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["X",EAST],
AXIS["Y",NORTH],
EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"],
AUTHORITY["EPSG","3857"]]
Origin = (-782715.169640224426985,6700469.899478564038873)
Pixel Size = (305.748113140704788,-305.748113140704788)
Metadata:
ABSTRACT=Cartographie topographique multi-échelles du territoire français issue des bases de données vecteur de l’IGN –réalisée selon un processus cartographique innovant fortement automatisé.
TITLE=PYRAMIDE SCANEXPRESS STANDARD
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -782715.170, 6700469.899) ( 7d 1'52.50"W, 51d26'43.61"N)
Lower Left ( -782715.170, 4304933.433) ( 7d 1'52.50"W, 36d 1'52.79"N)
Upper Right ( 1408887.305, 6700469.899) ( 12d39'22.50"E, 51d26'43.61"N)
Lower Right ( 1408887.305, 4304933.433) ( 12d39'22.50"E, 36d 1'52.79"N)
Center ( 313086.068, 5502701.666) ( 2d48'45.00"E, 44d14'25.01"N)
Band 1 Block=128x128 Type=Byte, ColorInterp=Red
Overviews: 3584x3917, 1792x1959, 896x979, 448x490, 224x245
Mask Flags: PER_DATASET ALPHA
Overviews of mask band: 3584x3917, 1792x1959, 896x979, 448x490, 224x245
Band 2 Block=128x128 Type=Byte, ColorInterp=Green
Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
Band 4 Block=128x128 Type=Byte, ColorInterp=Alpha
De: "Even Rouault" <even.rouault at spatialys.com>
À: "Hugues François" <hugues.francois at irstea.fr>
Cc: gdal-dev at lists.osgeo.org
Envoyé: Vendredi 5 Mai 2017 18:27:27
Objet: Re: [gdal-dev] WMTS "No zoom level found"
On vendredi 5 mai 2017 18:18:54 CEST Hugues François wrote:
> WMTS:http://wxs.ign.fr/{KEY}/geoportail/wmts?SERVICE=WMTS&REQUEST=GetCapabil
OK, so now try
gdalinfo "WMTS:http://wxs.ign.fr/{KEY}/geoportail/wmts?SERVICE=WMTS&REQUEST=GetCapabilities,layer=GEOGRAPHICALGRIDSYST"
as suggested by the subdataset name.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170505/2e6a1779/attachment-0001.html>
