[gdal-dev] WMTS "No zoom level found"
Even Rouault
even.rouault at spatialys.com
Fri May 5 11:56:30 PDT 2017
On vendredi 5 mai 2017 20:09:17 CEST Hugues François wrote:
> Sorry, it took me sometimes to answer. I don't know what happenned with the
> copy/paste from terminal but the url was truncated.
> However, it ran the gdalinfo with the right layer name and it is after this
> text.
So it looks like there's no issue with the server. The issue was likely in your XML
file but you don't necessarily need it. You can use the WMTS:.... name for
gdal_translate or gdalwarp operations.
If you want to try fixing your XML file, perhaps try removing the <DataWindow>
to see if that has an effect, or check the TileMatrixSet name, or ...
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170505/e789ec54/attachment-0001.html>
