[gdal-dev] What warnings in r38007 require casting int const to double?
Kurt Schwehr schwehr at gmail.com
Wed May 17 07:13:39 PDT 2017
+gdal-dev
On Wed, May 17, 2017 at 7:12 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Hi Even,
> Do you remember what warning by which compiler with this changeset?
> Thanks,
> -kurt
> https://trac.osgeo.org/gdal/changeset/38007
> "Message: Fix warnings about alteration of constant value"
>           if( dfDoubleRet > static_cast<double>(
>                                             std::numeric_limits<int>::max())
>               dfDoubleRet < static_cast<double>(
>                                             std::numeric_limits<int>::min())
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170517/ef95f64e/attachment-0001.html>
