[gdal-dev] What warnings in r38007 require casting int const to double?
Even Rouault
even.rouault at spatialys.com
Wed May 17 07:34:22 PDT 2017
On mercredi 17 mai 2017 07:13:39 CEST Kurt Schwehr wrote:
> +gdal-dev
> On Wed, May 17, 2017 at 7:12 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> > Hi Even,
> > Do you remember what warning by which compiler with this changeset?
Hum of course not :-) It might be some older compiler/distribution I tested before releasing
2.2.
I don't see indeed in the part you quote below why a compiler would complain.
But in the changeset the change related to GUIntBig is legitimate since big values of 64 bit
integers cannot be exactly represented as a 64 bit double.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170517/0720c8ad/attachment.html>
