[gdal-dev] MrSID Color Spaces
Martin Chapman
mchapman at hyperacktive.com
Wed May 17 08:10:42 PDT 2017
Its an enum value defined in at least version 8.0 and greater. Maybe in
earlier versions but I am using version 9.1.
Martin
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Wednesday, May 17, 2017 8:39 AM
To: Martin Chapman
Cc: 'SIMON Nicolas'; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] MrSID Color Spaces
On mercredi 17 mai 2017 08:26:00 CEST Martin Chapman wrote:
> Nicolas,
> Looks good bud! Thanks!
I've just applied it to trunk, but couldn't really test it since it seems my
MrSID version doesn't have those #define
Even
> Best regards,
> Martin
> From: SIMON Nicolas [mailto:nicolas.simon at spw.wallonie.be]
> Sent: Wednesday, May 17, 2017 4:41 AM
> To: Martin Chapman
> Cc: gdal-dev at lists.osgeo.org; Even Rouault
> Subject: RE: [gdal-dev] MrSID Color Spaces
> Martin,
> Could you test this patch ?
> Nicolas
> De : gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Even
> Rouault
> Envoyé : mardi 16 mai 2017 18:28
> À : Martin Chapman
> Cc : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] MrSID Color Spaces
> On mardi 16 mai 2017 10:13:52 CEST Martin Chapman wrote:
> > Even or Frank or whoever it may concern,
> > Not a big deal but I was trying to open a JP2 file using the MrSID
driver
> > and noticed that the mrsiddataset.cpp does not identify the color spaces
> > MRSID_LTI_COLORSPACE_GRAYSCALEA and MRSID_LTI_COLORSPACE_GRAYSCALEA_PM
> > configurations in the MrSIDRasterBand() constructor. I happen to have a
> two
> > band JP2 that is a grayscale image with an alpha channel. The color
> > interpretation comes back as GCI_undefined. Not that important but if
you
> > ever feel like fixing it, that would be nice.
> > The fix would go somewhere close to line 485 in mrsiddataset.cpp.
> Basically
> > just need to add a couple of more case statements in the switch
statement.
> Martin,
> Seems you are closed to a patch. Can you provide it ?
> Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170517/a893be2b/attachment-0001.html>
