[gdal-dev] MrSID Color Spaces
Even Rouault
even.rouault at spatialys.com
Wed May 17 08:31:20 PDT 2017
On mercredi 17 mai 2017 09:10:42 CEST Martin Chapman wrote:
> ItÂ’s an enum value defined in at least version 8.0 and greater. Maybe in
> earlier versions but I am using version 9.1.
Indeed, that's an *enum value*, not a #define !
typedef enum LTIColorSpace
LTI_COLORSPACE_GRAYSCALEA = LTI_COLORSPACE_GRAYSCALE |
LTI_COLORSPACE_MASK_ALPHA,
LTI_COLORSPACE_GRAYSCALEA_PM = LTI_COLORSPACE_GRAYSCALEA |
LTI_COLORSPACE_MASK_ALPHA_PRE_MULTIPLIED,
I interpreted your "Looks good" as "applied and successfully tested"...
I do have SDK 8 indeed, so I replaced the conditional test with:
#if defined(LTI_SDK_MAJOR) && LTI_SDK_MAJOR >= 8
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170517/bdd244e5/attachment.html>
