[gdal-dev] MrSID Color Spaces
Martin Chapman mchapman at hyperacktive.com
Wed May 17 08:50:40 PDT 2017
Even,
That's correct, I did not actually build it.  Our third party libraries are
built by another person on the team and it doesn't happen quick.  I thought
he was asking me whether it looks correct.  I apologize for the
mis-communication.
Best regards,
Martin
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Wednesday, May 17, 2017 9:31 AM
To: Martin Chapman
Cc: 'SIMON Nicolas'; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] MrSID Color Spaces
On mercredi 17 mai 2017 09:10:42 CEST Martin Chapman wrote:
> It's an enum value defined in at least version 8.0 and greater. Maybe in
> earlier versions but I am using version 9.1.
Indeed, that's an *enum value*, not a #define !
typedef enum LTIColorSpace
LTI_COLORSPACE_GRAYSCALEA = LTI_COLORSPACE_GRAYSCALE |
LTI_COLORSPACE_MASK_ALPHA,
LTI_COLORSPACE_GRAYSCALEA_PM = LTI_COLORSPACE_GRAYSCALEA |
LTI_COLORSPACE_MASK_ALPHA_PRE_MULTIPLIED,
I interpreted your "Looks good" as "applied and successfully tested"...
I do have SDK 8 indeed, so I replaced the conditional test with:
#if defined(LTI_SDK_MAJOR) && LTI_SDK_MAJOR >= 8
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170517/e8deadf7/attachment.html>
