[gdal-dev] Write overviews directly to S3
Jeremy Palmer JPalmer at linz.govt.nz
Thu May 18 01:39:19 PDT 2017
Hi All,
Is is possible to directly write external overview to a S3 bucket? With GDAL 2.1.2 I get an error reporting that seek is not supported when writing to vsis3:
gdaladdo /vsis3/my-bucket/data/1000.tif 2
ERROR 6: Seek not supported on writable /vsis3 files
ERROR 1: _tiffSeekProc:Resource temporarily unavailable
ERROR 1: _tiffWriteProc:Resource temporarily unavailable
ERROR 1: /vsis3/my-bucket/data/1000.tif.ovr:Error writing TIFF header
ERROR 1: TIFFAdvanceDirectory:/vsis3/my-bucket/data/1000.tif.ovr: Error fetching directory count
ERROR 1: TIFFLinkDirectory:Error fetching directory count
ERROR 1: Only read-only mode is supported for /vsicurl
Overview building failed.
I have both read and write access to this bucket and gdalinfo works on the source S3 file.
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
