[gdal-dev] Write overviews directly to S3
Even Rouault
even.rouault at spatialys.com
Thu May 18 02:12:12 PDT 2017
Hi Jeremy,
> Is is possible to directly write external overview to a S3 bucket? With GDAL
> 2.1.2 I get an error reporting that seek is not supported when writing to
> vsis3:
No, /vsis3/ only supports sequential writing in files (the original use case was to generate and
upload a huge CSV file on the fly). I don't have all the details in mind but random writing
might not be possible given the S3 API constraints, at least with the multipart upload API
which is used currently.
And another constraint of the current implementation is that a /vsis3/ file is either read-only
or write-only, but not a mix of both, which would be needed for gdaladdo internal overviews.
Perhaps external overview would work, but I'm not completely sure as creating a TIFF file
might require seeking.
Perhaps a fully fledged read-write-update file system would be possible, but that wasn't in
my initial design constraints.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170518/995bbb1a/attachment.html>
