[gdal-dev] Reading sentinel 2 L2A datasets
Ari Jolma ari.jolma at gmail.com
Thu Nov 2 23:59:37 PDT 2017
Just a comment on this post. It was initially blocked since it is > 50
kB. I've now increased the size limit to 100 kB.
Ari
Róbert Špir kirjoitti 03.11.2017 klo 08:55:
> Hi all,
> I'm using GDAL to process sentinel-2 data (in c++). I have no problem
> processing S2B and S2A L1C datasets, I can open them, read the
> subdatasets and process the data.
> But when I try to open L2A dataset, it looks like there are no
> subdatasets and I cannot access the bands.
> I have attached gdalinfo output from this dataset and the dataset xml.
> Is there any way how I can access the subdatasets or this type of
> dataset is not currently supported in GDAL?
> Thanks,
> Robert
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171103/9dafa271/attachment.html>
