[gdal-dev] Reading sentinel 2 L2A datasets
Even Rouault
even.rouault at spatialys.com
Fri Nov 3 01:30:22 PDT 2017
On vendredi 3 novembre 2017 07:55:57 CET Róbert Špir wrote:
> Hi all,
> I'm using GDAL to process sentinel-2 data (in c++). I have no problem
> processing S2B and S2A L1C datasets, I can open them, read the subdatasets
> and process the data.
> But when I try to open L2A dataset, it looks like there are no subdatasets
> and I cannot access the bands.
> I have attached gdalinfo output from this dataset and the dataset xml. Is
> there any way how I can access the subdatasets or this type of dataset is
> not currently supported in GDAL?
Robert,
yes currently the newest formulation of L2A datasets ("SAFE_COMPACT") is not supported
by the driver. The original formulation is, but Copernicus changed the format a bit
afterwards, so some adaptation in the driver would be needed.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171103/3070f9b7/attachment.html>
