[gdal-dev] Reading sentinel 2 L2A datasets
Róbert Špir spir.robert at gmail.com
Fri Nov 3 02:54:22 PDT 2017
Thanks for the info, are there any plans to add this support in the near
future?
Robert
On Fri, Nov 3, 2017 at 9:30 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 3 novembre 2017 07:55:57 CET Róbert Špir wrote:
> > Hi all,
> > I'm using GDAL to process sentinel-2 data (in c++). I have no problem
> > processing S2B and S2A L1C datasets, I can open them, read the
> subdatasets
> > and process the data.
> > But when I try to open L2A dataset, it looks like there are no
> subdatasets
> > and I cannot access the bands.
> > I have attached gdalinfo output from this dataset and the dataset xml. Is
> > there any way how I can access the subdatasets or this type of dataset is
> > not currently supported in GDAL?
> Robert,
> yes currently the newest formulation of L2A datasets ("SAFE_COMPACT") is
> not supported by the driver. The original formulation is, but Copernicus
> changed the format a bit afterwards, so some adaptation in the driver would
> be needed.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171103/78c99046/attachment.html>
