[gdal-dev] WCS GetCoverage with AxisOrder swap
Ari Jolma
ari.jolma at gmail.com
Wed Nov 8 04:50:54 PST 2017
Ari Jolma kirjoitti 08.11.2017 klo 13:48:
> for MapServer and GeoServer I need to have at least two hack options
> (NoOffsetSwap and NoGridEnvelopeSwap, maybe there could be only one).
> I have not yet checked if the rasters returned from those two are ok.
The rasters that those servers return are ok. I just need the one
additional hack option for GeoServer to swap the axis names for the
GetCoverage request.
I also don't need to use the GridFunction information.
BTW, it seems that GDAL driver options are usually all upcase. Is that
just a convention, and could it perhaps be violated? The reason for
options like "PreferredFormat=xxx" for the WCS driver (instead of
"PREFERREDFORMAT=xxx") is that 'PreferredFormat' is the name of the
element in the WCS_GDAL XML. My approach in the new WCS driver is to use
options to set values in the WCS_GDAL XML since that XML file is in the
cache and meant to be maintained by the driver.
Ari
