[gdal-dev] WCS GetCoverage with AxisOrder swap
Ari Jolma
ari.jolma at gmail.com
Wed Nov 8 03:48:49 PST 2017
I've got to the point in the new WCS driver development, where I'm
trying to issue GetCoverage request to a GeoServer, which is serving
data in EPSG that has axis order swapped.
This is related to the earlier discussion
https://lists.osgeo.org/pipermail/gdal-dev/2017-April/046366.html
The data serving is at
https://msp.smartsea.fmi.fi/geoserver/wcs?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=smartsea__eusm2016-EPSG2393
The boundedBy tells that the axisLabels are "Y X" and the lower corner
is "6543350.381089335 3061592.6391462097" and upper corner is
"7307056.899896299 3432141.361396798". This makes sense, in that EPSG X
(easting) runs up from 3000000 and Y (northing) runs up from 6500000.
What I don't understand is why I need to make the GetCoverage request
with subset=Y(3061592,3061632) and subset=X(7307016,7307056). If I
define them as I would expect
https://msp.smartsea.fmi.fi/geoserver/wcs?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=smartsea__eusm2016-EPSG2393&FORMAT=image%2Ftiff&SUBSET=X%283061592.63914621,3061632.65520693%29&SUBSET=Y%287307016.88383558,7307056.8998963%29
I get "Empty intersection after subsetting".
A MapServer that serves data with EPSG that has axis order swapped is at
http://194.66.252.155/cgi-bin/BGS_EMODnet_bathymetry/ows?SERVICE=WCS&REQUEST=DescribeCoverage&version=2.0.1&coverageid=BGS_EMODNET_CentralMed-MCol
It works using the above logic. However, it does not have GridFunction,
which GeoServer has (it is "+2 +1", i.e., the data is east first, then
north).
and Rasdaman server at
http://ows.rasdaman.org/rasdaman/ows?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=BlueMarbleCov
Works using the above logic. However, it *has* GridFunction, which is
the same as GeoServer has. However, it has the order of offsetVectors
swapped - which I think is correct (as is also written here
https://lists.osgeo.org/pipermail/gdal-dev/2017-April/046421.html)
So, I can make Rasdaman work for CRS with swapped order by default (also
the returned geotiff is ok), and for MapServer and GeoServer I need to
have at least two hack options (NoOffsetSwap and NoGridEnvelopeSwap,
maybe there could be only one). I have not yet checked if the rasters
returned from those two are ok.
Ari
