[gdal-dev] Grib2 Question
Kurt Schwehr
schwehr at gmail.com
Wed Nov 8 10:02:48 PST 2017
https://trac.osgeo.org/gdal/changeset/40664
On Tue, Nov 7, 2017 at 8:03 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
> I'm pretty sick today, so I'll hold off making the change until tomorrow
> (unless anyone wants to beat me to it)
> -kurt
> On Tue, Nov 7, 2017 at 4:02 PM, Roarke Gaskill <roarke.gaskill at weather.com
> > wrote:
>> > Unfortunately given how the GRIB degrib and underlying libaries used
>> are done, you cannot get metadata without processing the whole file.
>> Oh, so the OOM would happen even when calling gdalinfo? I was assuming it
>> was later processing that was getting the OOM.
>> On Tue, Nov 7, 2017 at 5:58 PM, Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> On mardi 7 novembre 2017 17:45:57 CET Roarke Gaskill wrote:
>>> > It seems inappropriate (even as a quick hack) to put the size check in
>>> the
>>> > grib parser.
>>> If we default to knMaxAllloc = INT_MAX, given that *ndpts is g2int, then
>>> the check will be a no-op. Actually the compiler and/or static analyzers
>>> will probably complain about that... So INT_MAX - 1 is probably a better
>>> choice :-)
>>> > With the check there, you are not able to run simple utilities
>>> > like gdalinfo on large files. What if I wanted to use gdalinfo to find
>>> out
>>> > if the file is too big to process?
>>> Unfortunately given how the GRIB degrib and underlying libaries used are
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>> *Roarke **Gaskill *|Senior Software Engineer
>> *e:* roarke.gaskill at weather.com
>> <http://weather.com/apps> <http://weather.com/apps>
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171108/b4d42bdc/attachment-0001.html>
