[gdal-dev] WCS GetCoverage with AxisOrder swap
Ari Jolma
ari.jolma at gmail.com
Wed Nov 8 13:01:34 PST 2017
Even Rouault kirjoitti 08.11.2017 klo 17:31:
> On mercredi 8 novembre 2017 15:50:48 CET Piero Campalani wrote:
> > This order is what can be referred to in the GridFunction: +1 --> first
> > GRID axis, +2 --> second GRID axis, etc.
Ok, this tells me that the axisOrder attribute in sequenceRule
determines how to consider the GridEnvelope and the order of the
offsetVectors in the Grid element.
> And thus MapServer output at
> http://194.66.252.155/cgi-bin/BGS_EMODnet_bathymetry/ows?SERVICE=WCS&REQUEST=DescribeCoverage&version=2.0.1&coverageid=BGS_EMODNET_CentralMed-MCol
> could probably be correct, but it would be better for
> RectifiedGrid.axisLabels to be changed to "long lat" to better
> reflect what is done.
At least it fixes the driver for MapServer in this case (no hack options
needed) since it does not define the axisOrder.
> And GeoServer output at
> https://msp.smartsea.fmi.fi/geoserver/wcs?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=smartsea__eusm2016-EPSG2393
> would either need to remove the GridFunction (ala MapServer) or keep
> it and invert the order in which its offsetVector appear (ala Rasdaman)
Invert the offsetVector order *and* invert the axis in GridEnvelope
(otherwise the size is wrong).
> And for WCS subsetting, when you write something like
> SUBSET=AXIS_NAME(min,max),
> where AXIS_NAME should come from ? From the RectifiedGrid.axisLabels I
> guess ?
> (to be opposed to CoverageDescription.boundedBy.Envelope at axisLabels)
> Then in Ari's test with GeoServer
> https://msp.smartsea.fmi.fi/geoserver/wcs?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=smartsea__eusm2016-EPSG2393,
> in theory "i" and "j" should be the axis requested ?
That does not work -- it's good that they are different since that shows
it is not ok (invalid axis label error). Maybe the logic is related to
the axis names? It's hard to tell since I don't find the logic in the
GeoServer source code.
Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171108/67bb96db/attachment.html>
