[gdal-dev] Enable --with-static-proj4 by default if ESRI FGDB option is given on Linux
Even Rouault
even.rouault at spatialys.com
Wed Nov 15 13:19:15 PST 2017
> To save others from this hellish debugging process, it might be worth
> either checking for the FGDB libraries and throwing an error if GDAL is
> configured without --wtih-static-proj4=location or setting that option by
> default.
./configure should already output a warning about that situation at the end:
https://trac.osgeo.org/gdal/changeset/37668
I've turned that as an error:
https://trac.osgeo.org/gdal/changeset/40724
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171115/b1071e72/attachment.html>
