[gdal-dev] Enable --with-static-proj4 by default if ESRI FGDB option is given on Linux
Chris Marsh chris.marsh at usask.ca
Wed Nov 15 14:20:12 PST 2017
As I have been unable to solve my strange proj4 related issues  as per
http://osgeo-org.1560.x6.nabble.com/Failed-to-initialize-PROJ-4-with-quot-quot-td5338323.html
I wonder if this is at all related to my issues and why changing proj4
versions makes no difference....
Is --without-fgdb the correct way to disable this feature so I can test?
Cheers
Chris
On 15 November 2017 at 15:19, Even Rouault <even.rouault at spatialys.com>
wrote:
> > To save others from this hellish debugging process, it might be worth
> > either checking for the FGDB libraries and throwing an error if GDAL is
> > configured without --wtih-static-proj4=location or setting that option by
> > default.
> ./configure should already output a warning about that situation at the
> end:
> https://trac.osgeo.org/gdal/changeset/37668
> I've turned that as an error:
> https://trac.osgeo.org/gdal/changeset/40724
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171115/b2bbb36e/attachment-0001.html>
