[gdal-dev] Multidimensional raster support in GDAL
Ari Jolma
ari.jolma at gmail.com
Wed Nov 22 07:33:54 PST 2017
Even Rouault kirjoitti 22.11.2017 klo 15:11:
> On mercredi 22 novembre 2017 14:38:55 CET Ari Jolma wrote:
> > Even Rouault kirjoitti 21.11.2017 klo 16:06:
> > > gdal_translate (actually GDALDatasetCopyWholeRaster()) uses the
> > > INTERLEAVE=PIXEL/BAND metadata item of the IMAGE_STRUCTURE domain as a
> > > hint whether to read band by band or all bands together
> > > So if you add the following, it should request all bands :
> > > poDS->SetMetadataItem("INTERLEAVE", "PIXEL", "IMAGE_STRUCTURE")
> > I don't see that happening in the case of WCS driver:
> > PIXEL_INTERLEAVE=TRUE is my option to set the metadata item but it could
> > be set with option INTERLEAVE=PIXEL, which GDALDatasetCopyWholeRaster()
> > examines.
> Probably related to the logic of WCSDataset::TestUseBlockIO() which
> given your area of interest size of 2x2 will force bocked IO instead
> of direct IO
> If PIXEL_INTERLEAVE=TRUE is set, you might want to force the
> implementation of WCSRasterBand::IReadBlock() to read all the bands.
I guess the situation is same for WCSDataset::IRasterIO which may be
called BandCount and BandMap.
Works fine.
Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171122/6b8add21/attachment.html>
