[gdal-dev] question about --config cmd line option
Even Rouault
even.rouault at spatialys.com
Wed Oct 18 11:51:10 PDT 2017
On mercredi 18 octobre 2017 11:40:55 CEST Victor Chernetsky wrote:
> Hello,
> I am developing the AmigoCloud driver for GDAL, and I have a question about
> '-config' command line option.
> When I use a space it seems to work, but when I use '=', which seems like a
> correct way of doing it, I get the token string with unwanted chars at the
> end of it.
Victor,
How surprising it might be, the space separator is the documented (see end of
http://gdal.org/gdal_utilities.html) and implemented way of separating the key
and the value.
Even
http://www.spatialys.com
