[gdal-dev] question about --config cmd line option
Victor Chernetsky victor at amigocloud.com
Wed Oct 18 11:55:53 PDT 2017
Thanks Even. I just wanted to confirm it.
On Wed, Oct 18, 2017 at 11:51 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 18 octobre 2017 11:40:55 CEST Victor Chernetsky wrote:
> > Hello,
> > I am developing the AmigoCloud driver for GDAL, and I have a question
> about
> > '-config' command line option.
> > When I use a space it seems to work, but when I use '=', which seems
> like a
> > correct way of doing it, I get the token string with unwanted chars at
> the
> > end of it.
> Victor,
> How surprising it might be, the space separator is the documented  (see
> end of
> http://gdal.org/gdal_utilities.html) and implemented way of separating
> the key
> and the value.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171018/6ac736e1/attachment.html>
