[gdal-dev] Using ogr2ogr to convert from csv - drops text after number
Even Rouault even.rouault at spatialys.com
Wed Oct 25 13:00:41 PDT 2017
John,
The issue is a wrong detection of the field type in the GeoRSS/Atom
driver, which I just fixed per
https://trac.osgeo.org/gdal/ticket/7108
There's no workaround, apart from grabbing a build with the above fix.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171025/c519628d/attachment.html>
