[gdal-dev] Open Jpeg 2.3.0 and OPJ_NUM_THREADS
N. Farah
nfarah at hotmail.com
Tue Oct 31 12:50:15 PDT 2017
Thanks for the quick response. I'm not using latest GDAL and was curious where that multi-threading enabling was made ? Was it some where in GDAL code or through an option in the openjpeg 2.3.0 API ?
Thanks
Noureddine Farah
Sent: Tuesday, October 31, 2017 3:47:01 PM
To: gdal-dev at lists.osgeo.org
Cc: N. Farah
Subject: Re: [gdal-dev] Open Jpeg 2.3.0 and OPJ_NUM_THREADS
On mardi 31 octobre 2017 19:39:23 CET N. Farah wrote:
> Hi,
> In http://gdal.org/frmt_jp2openjpeg.html under 'Thread Support' section
> there is the following:
> "Starting with GDAL 2.3, this multi-threading at code-block level is
> automatically enabled by GDAL".
> Was meant "Starting with OpenJpeg 2.3, ..." ?
No, was meant starting with GDAL 2.3 (the current dev version). And that requires openjpeg >= 2.2 as well.
> If yes, was that enabling made in the 'OpenJpeg 2.3' library or was made in
> GDAL ?
openjpeg >= 2.2 (actually 2.1.2, but I restricted to 2.2 or later) brings multithreading decoding at codeblock level, and GDAL trunk automatically enables it.
So the doc is correct I think, but I know that those similar version numbers between GDAL and openjpeg can be confusing.
Bottom line: use the latest and greatest of both to get the better performance.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171031/e915953f/attachment.html>
