[gdal-dev] Call for discussion on RFC68: C++11 compilation mode
Even Rouault even.rouault at spatialys.com
Tue Sep 5 02:46:39 PDT 2017
Hi Tamas,
this is great! Thanks
Even
> Hi Even,
> The new SDK-s have now been added.
> Best regards,
> Tamas
> 2017-08-29 15:18 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> > Hi Even,
> > Yes, I'm planning to include msvc2015/2017 versions shortly.
> > Best regards,
> > Tamas
> > Sent from my iPhone
> > 2017. aug. 14. dátummal, 19:02 időpontban Even Rouault <
> > even.rouault at spatialys.com> írta:
> > > Hi Tamas,
> > > Unless I'm mistaken your gisinternals.com builds don't include MSVC
> > 2015 currently. Right ? Do you have any plans to do so ? Currently the
> > GDAL
> > AppVeyor target uses SDKSs from gisinternals to do builds with a number of
> > third-party libraries.
> > > Even
> > > > This is a call for discussion on RFC68 to set C++11 to be the minimum
> > C++
> > > > language version for GDAL trunk. I've drafted the RFC based on work by
> > > > Mateusz.
> > > > https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> > > > There was initial discussions back in January of this year:
> > > > https://lists.osgeo.org/pipermail/gdal-dev/2017-> >
> > January/thread.html#45786
> > > > Cheers,
> > > > -kurt
> > > > Engineer at Google
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170905/84a18304/attachment.html>
