[gdal-dev] Call for discussion on RFC68: C++11 compilation mode
Kurt Schwehr schwehr at gmail.com
Mon Sep 11 16:17:40 PDT 2017
RFC68 was voted on and adopted:
https://lists.osgeo.org/pipermail/gdal-dev/2017-September/047139.html
On Tue, Sep 5, 2017 at 2:46 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Tamas,
> this is great! Thanks
> Even
> > Hi Even,
> > The new SDK-s have now been added.
> > Best regards,
> > Tamas
> > 2017-08-29 15:18 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> > > Hi Even,
> > > Yes, I'm planning to include msvc2015/2017 versions shortly.
> > > Best regards,
> > > Tamas
> > > Sent from my iPhone
> > > 2017. aug. 14. dátummal, 19:02 időpontban Even Rouault <
> > > even.rouault at spatialys.com> írta:
> > > > Hi Tamas,
> > > > Unless I'm mistaken your gisinternals.com builds don't include MSVC
> > > 2015 currently. Right ? Do you have any plans to do so ? Currently the
> > > GDAL
> > > AppVeyor target uses SDKSs from gisinternals to do builds with a
> number of
> > > third-party libraries.
> > > > Even
> > > > > This is a call for discussion on RFC68 to set C++11 to be the
> minimum
> > > C++
> > > > > language version for GDAL trunk. I've drafted the RFC based on
> work by
> > > > > Mateusz.
> > > > > https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> > > > > There was initial discussions back in January of this year:
> > > January/thread.html#45786
> > > > > Cheers,
> > > > > -kurt
> > > > > Engineer at Google
> > > > Spatialys - Geospatial professional services
> > > > http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/57f1e602/attachment.html>
