[gdal-dev] OGRSpatialReference::IsSame returning TRUE unexpectedly
Even Rouault
even.rouault at spatialys.com
Tue Sep 5 14:02:29 PDT 2017
> I assume my understanding of IsSame is flawed so any clarification would be
> a big help.
Matt,
Your understanding of IsSame() is correct. You just hit a bug. I've fixed it per https://
trac.osgeo.org/gdal/ticket/7029. You can see the changeset code as a workaround to add in
your own code if you need.
IsSame() is a "smart" comparison, ie it tries to abstract away unsignificant differences like the
PROJCS text value that don't participate really to the SRS and can vary over formats, data
producers, etc... The issue here is that web-mercator (EPSG:3857) and WGS84-mercator
(EPSG:3395) are represented the same way at the GEOGCS and projection levels. The only
difference is that GDAL creates a EXTENSION["PROJ4", ...] node in the web-mercator case to
really use the spherical definition. And IsSame() before my fix neglected to compare that
extension node. So you were a bit unlucky since that must be pretty much the only pair of
EPSG entries in that situation.
My initial tought was to compare the authority codes/nodes when they exist on both sides,
but I was wondering if there are not cases where you'd have the same SRS registered in 2
different catalogs. Presumably within the same catalog, a different code should mean a
different CRS, but I'm not even completely sure you couldn't find oddities. I was thinking to
EPSG:3857 vs the deprecated EPSG:3785, but this isn't a good example, since they differ on
the DATUM. So currently IsSame() returns FALSE on that pair, although I guess one might
consider them as equivalent (the deprecated version is just a buggy expression on the
current EPSG:3857). Or not...
You also have the situation where really different CRS (IsSame() == FALSE) ends up being
translated the same way as proj.4 strings...
So it is actually not obvious to define the semantics of IsSame(). It should at least return
FALSE for CRS that are clearly different (coordinate transformation results in differences).
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170905/38d552f8/attachment.html>
