[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Even Rouault even.rouault at spatialys.com
Wed Sep 6 09:38:01 PDT 2017
On mercredi 6 septembre 2017 09:14:10 CEST Kurt Schwehr wrote:
> Now that Tamas has added the msvc2015/2-17SDK's, I'd like to call a vote by
> the PSC on RFC68: C++11 compilation mode.
> The draft is here:
>  https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
+1
Just a comment regarding "Remove continuous build targets that do not support C++11
from Travis-CI and AppVeyor". We'll have to be careful as there are subtle differences in
configurations / drivers tested in some of the non C++11 capable configurations that would
be good to keep. But that should indeed reduce the number of configurations.
Even
> -Kurt
> > > Hi Even,
> > > The new SDK-s have now been added.
> > > Best regards,
> > > Tamas
> > > 2017-08-29 15:18 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> > > > Hi Even,
> > > > Yes, I'm planning to include msvc2015/2017 versions shortly.
> > > > Best regards,
> > > > Tamas
> > > > 2017. aug. 14. dátummal, 19:02 időpontban Even Rouault <
> > > > even.rouault at spatialys.com> írta:
> > > > > Hi Tamas,
> > > > > Unless I'm mistaken your gisinternals.com builds don't include MSVC
> > > > 2015 currently. Right ? Do you have any plans to do so ? Currently the
> > > > GDAL
> > > > AppVeyor target uses SDKSs from gisinternals to do builds with a
> > number of
> > > > third-party libraries.
> > > > > Even
> > > > > > This is a call for discussion on RFC68 to set C++11 to be the
> > minimum
> > > > C++
> > > > > > language version for GDAL trunk. I've drafted the RFC based on
> > work by
> > > > > > Mateusz.
> > > > > > There was initial discussions back in January of this year:
> > https://lists.osgeo.org/pipermail/gdal-dev/2017January/thread.html#45786
> > > > > > Cheers,
> > > > > > -kurt
> > > > > > Engineer at Google
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170906/27cab3bc/attachment-0001.html>
