[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Joaquim Luis
jluis at ualg.pt
Wed Sep 6 10:14:05 PDT 2017
Wait, does this means that VS2013 will no longer be supported?
That's awful because I'll have to rebuild all my dependencies and honestly
do not understand what compiler dlls must be distributed with the code
(with VS2013 I only has to ship in 2 dlls) and the last thing I want is to
force users to go previously install the MS distributable file (I maintain
the GMR Windows installer).
Joaquim
> Now that Tamas has added the msvc2015/2-17SDK's, I'd like to call a vote
> by the PSC on RFC68: C++11 compilation mode.
> The draft is here:
> https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> -Kurt
>>> Hi Even,
>>> The new SDK-s have now been added.
>>> Best regards,
>>> Tamas
>>> 2017-08-29 15:18 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
>>> > Hi Even,
>>> > Yes, I'm planning to include msvc2015/2017 versions shortly.
>>> > Best regards,
>>> > Tamas
>>> > 2017. aug. 14. dátummal, 19:02 időpontban Even Rouault <
>>> > even.rouault at spatialys.com> írta:
>>> > > Hi Tamas,
>>> > > Unless I'm mistaken your gisinternals.com builds don't include MSVC
>>> > 2015 currently. Right ? Do you have any plans to do so ? Currently
>>> the
>>> > GDAL
>>> > AppVeyor target uses SDKSs from gisinternals to do builds with a
>>> number of
>>> > third-party libraries.
>>> > > Even
>>> > > > This is a call for discussion on RFC68 to set C++11 to be the
>>> minimum
>>> > C++
>>> > > > language version for GDAL trunk. I've drafted the RFC based on
>>> work by
>>> > > > Mateusz.
>>> > > > There was initial discussions back in January of this year:
>>> https://lists.osgeo.org/pipermail/gdal-dev/2017January/thread.html#45786
>>> > > > Cheers,
>>> > > > -kurt
>>> > > > Engineer at Google
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170906/cbb0e7b0/attachment-0001.html>
