[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Mateusz Loskot
mateusz at loskot.net
Wed Sep 6 10:33:06 PDT 2017
On 6 September 2017 at 19:11, Even Rouault <even.rouault at spatialys.com> wrote:
> On mercredi 6 septembre 2017 19:04:34 CEST Mateusz Loskot wrote:
>> On 6 September 2017 at 18:58, Andrew Bell <andrew.bell.ia at gmail.com> wrote:
>> > On Wed, Sep 6, 2017 at 12:14 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
>> >> Now that Tamas has added the msvc2015/2-17SDK's, I'd like to call a
>> >> vote
>> >> by the PSC on RFC68: C++11 compilation mode.
>> >> The draft is here:
>> >> https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
>> > I'm late to the party, but I guess I don't understand a few things in
>> > the
>> > RFC.
>> > In Plan: If c++11 mode is enabled, won't ALL code need to be C++11
>> > compliant, rather than just new code?
>> Any existing code which does not compile as C++11 will have to be updated.
> This is mostly a theoretical case. We have buildbots that compile in C++11
> and ran tests for a couple of years now (and one in C++14). And by default
> (since GDAL 2.2 I think) ./configure already enables C++11 on all C++11
> capable compilers.
Yes, indeed.
I gave a 'generic' answer.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
