[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Dmitry Baryshnikov bishop.dev at gmail.com
Wed Sep 6 11:21:14 PDT 2017
I'm not a PSC member, but like to note the great work Kurt has done on
C++11 compilation mode.
I strongly support this RFC.
Best regards,
     Dmitry
06.09.17 19:14, Kurt Schwehr пишет:
> Now that Tamas has added the msvc2015/2-17SDK's, I'd like to call a vote by
> the PSC on RFC68: C++11 compilation mode.
> The draft is here:
>   https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> -Kurt
>>> Hi Even,
>>> The new SDK-s have now been added.
>>> Best regards,
>>> Tamas
>>> 2017-08-29 15:18 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
>>>> Hi Even,
>>>> Yes, I'm planning to include msvc2015/2017 versions shortly.
>>>> Best regards,
>>>> Tamas
>>>> 2017. aug. 14. dátummal, 19:02 időpontban Even Rouault <
>>>> even.rouault at spatialys.com> írta:
>>>>> Hi Tamas,
>>>>> Unless I'm mistaken your gisinternals.com builds don't include MSVC
>>>> 2015 currently. Right ? Do you have any plans to do so ? Currently the
>>>> GDAL
>>>> AppVeyor target uses SDKSs from gisinternals to do builds with a
>> number of
>>>> third-party libraries.
>>>>> Even
>>>>>> This is a call for discussion on RFC68 to set C++11 to be the
>> minimum
>>>> C++
>>>>>> language version for GDAL trunk. I've drafted the RFC based on
>> work by
>>>>>> Mateusz.
>>>>>> There was initial discussions back in January of this year:
>> https://lists.osgeo.org/pipermail/gdal-dev/2017January/thread.html#45786
>>>>>> Cheers,
>>>>>> -kurt
>>>>>> Engineer at Google
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170906/19616c8f/attachment-0001.html>
