[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Even Rouault
even.rouault at spatialys.com
Fri Sep 8 05:18:42 PDT 2017
On mercredi 6 septembre 2017 11:46:03 CEST Kurt Schwehr wrote:
> Joaquim,
> Please give it another go at explaining what this use case is and the
> issues with it. I didn't follow your comments about the need for VS2013.
> If users are on a legacy compiler (w.r.t. to C++11), can they not be served
> by the 2.2 branch? How does that use case fair with the impending GEOS
> 3.7.0 requiring a minimum of C++11?
FYI, just discovered today that Poppler 0.58 requires C++11 as well.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170908/7f423b91/attachment.html>
