[gdal-dev] RFC68: C++11 compilation mode - Call for vote on adoption
Joaquim Luis
jluis at ualg.pt
Wed Sep 6 12:21:24 PDT 2017
Kurt,
The Tamas SDKs are not enough as to provide all the dependencies to a GDAL
Win installation. It miss all those dlls (didn't check if the list is
complete) that the VS2015/17 builds now depend on. So if one wants to
distribute a program that depends on GDAL (GMT, in y case) that long list
of dlls must be supplied as well or otherwise tell users that they have to
install a MS distributable package.
Not a killer feature but annoying certainly.
Yes, if one remains at GDAL <= 2.2 this issue does not exist.
I'm not building GDAL against GEOS so didn't know about it C++11
requirement.
Side and non relevant info, 3 weeks ago I was at the Southern Hemisphere.
Joaquim
api-ms-win-core-console-l1-1-0.dll
api-ms-win-core-datetime-l1-1-0.dll
api-ms-win-core-debug-l1-1-0.dll
api-ms-win-core-errorhandling-l1-1-0.dll
api-ms-win-core-file-l1-1-0.dll
api-ms-win-core-file-l1-2-0.dll
api-ms-win-core-file-l2-1-0.dll
api-ms-win-core-handle-l1-1-0.dll
api-ms-win-core-heap-l1-1-0.dll
api-ms-win-core-interlocked-l1-1-0.dll
api-ms-win-core-libraryloader-l1-1-0.dll
api-ms-win-core-localization-l1-2-0.dll
api-ms-win-core-memory-l1-1-0.dll
api-ms-win-core-namedpipe-l1-1-0.dll
api-ms-win-core-processenvironment-l1-1-0.dll
api-ms-win-core-processthreads-l1-1-0.dll
api-ms-win-core-processthreads-l1-1-1.dll
api-ms-win-core-profile-l1-1-0.dll
api-ms-win-core-rtlsupport-l1-1-0.dll
api-ms-win-core-string-l1-1-0.dll
api-ms-win-core-synch-l1-1-0.dll
api-ms-win-core-synch-l1-2-0.dll
api-ms-win-core-sysinfo-l1-1-0.dll
api-ms-win-core-timezone-l1-1-0.dll
api-ms-win-core-util-l1-1-0.dll
api-ms-win-crt-conio-l1-1-0.dll
api-ms-win-crt-convert-l1-1-0.dll
api-ms-win-crt-environment-l1-1-0.dll
api-ms-win-crt-filesystem-l1-1-0.dll
api-ms-win-crt-heap-l1-1-0.dll
api-ms-win-crt-locale-l1-1-0.dll
api-ms-win-crt-math-l1-1-0.dll
api-ms-win-crt-multibyte-l1-1-0.dll
api-ms-win-crt-private-l1-1-0.dll
api-ms-win-crt-process-l1-1-0.dll
api-ms-win-crt-runtime-l1-1-0.dll
api-ms-win-crt-stdio-l1-1-0.dll
api-ms-win-crt-string-l1-1-0.dll
api-ms-win-crt-time-l1-1-0.dll
api-ms-win-crt-utility-l1-1-0.dll
> Joaquim,
> Please give it another go at explaining what this use case is and the
> issues with it. I didn't follow your comments about the need for
> VS2013. If users >are on a legacy compiler (w.r.t. to C++11), can they
> not be served by the 2.2 branch? How does that use case fair with the
> impending GEOS 3.7.0 >requiring a minimum of C++11?
> Thanks,
> -kurt
> P.S. Doesn't really matter, but here is where I upped the version for VS
> on Aug 14 after some discussion with Even:
> https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11?action=diff&version=9&old_version=8
> On Wed, Sep 6, 2017 at 11:23 AM, Mateusz Loskot <mateusz at loskot.net>
> wrote:
>> On 6 September 2017 at 20:18, Joaquim Luis <jluis at ualg.pt> wrote:
>>> On Wed, 06 Sep 2017 18:34:06 +0100, Mateusz Loskot
>>> <mateusz at loskot.net> wrote:
>>>> On 6 September 2017 at 19:14, Joaquim Luis <jluis at ualg.pt> wrote:
>>>>> Wait, does this means that VS2013 will no longer be supported?
>>>> With respect, Kurt has been asking for comments for very long time.
>>> Yes that's true, but always understood that VS2013 would be the
>>> minimum.
>> Kurt posted [1] updated RFC 68 three weeks ago.
>> It would be enough to have a glance to see VS2015.
>> [1] https://lists.osgeo.org/pipermail/gdal-dev/2017-August/046951.html
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170906/e1f60cdb/attachment.html>
