[gdal-dev] Opening gridded xyz data that is out of order
Mark Johnson
mj10777 at googlemail.com
Mon Sep 11 07:44:52 PDT 2017
This will do the same, just replace the EPSG code number:
gdal_translate -ot Float32 -a_srs EPSG:25833 ../xyz/390_5820.dhhn92.txt
../2007.390_5820.dhhn92.25833.tif
Mark
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/9146091f/attachment.html>
