[gdal-dev] illegal axis orientation combination when re-projecting
    Nick Cummins
    nickmcummins at icloud.com
    Tue Sep 12 16:47:09 PDT 2017
I am using Arch Linux (continuous/rolling distro), using gdal from the official repositories.
Using proj. 4.9.3-1 from official repos.
As mentioned, previously (within the past month) the first re-projection example was working fine. Suddenly today I was analyzing a different tile and ran into the error, and I have not made any changes to my setup that I am aware of that would change behavior.
Output of running ogr2ogr with valgrind in attached file.
Thanks,
Nick
On Sep 12, 2017, at 04:28 PM, Even Rouault <even.rouault at spatialys.com> wrote:
On mardi 12 septembre 2017 23:08:13 CEST you wrote:
> The source projection is contained in the accompanying .prj file in the zip,
> so it's probably easiest just to download and extract the zip.
I can't reproduce any crash nor error on Ubuntu 16.04 with gdal trunk, head of 2.2 branch or 2.2.1 release.
Which OS do you run ?
If you build GDAL yourself, which configure command line did you use ?
Which proj.4 version do you use ?
Since you probably run Linux from the crash message, can you install valgrind if not already done and run
valgrind ogr2ogr -f "GeoJSON" -t_srs EPSG:4326 dest.json TOWNSSURVEY_POLY.shp
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170912/ce137632/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170912/ce137632/attachment.txt>
