[gdal-dev] Running Tests
Mateusz Loskot mateusz at loskot.net
Tue Sep 26 05:42:22 PDT 2017
On 26 September 2017 at 14:28, Andrew Bell <andrew.bell.ia at gmail.com> wrote:
> P.S. - It seems strange to use python as a CI interface to a C/C++ library.
> Is there a reason the test harness isn't in C/C++?
Historical.
Python was obvious choice as simple platform.
Python kills two targets (three) at the same time: Python API and C/C++API
Decade ago I realised limitations of Python-only tests and started
scratching basic C++ tests suite
https://trac.osgeo.org/gdal/changeset/10613/
It's still there and its fairly convenient to use, if you need to
run/test/debug GDAL at C/C++ level.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
