[gdal-dev] Running Tests
Even Rouault
even.rouault at spatialys.com
Tue Sep 26 06:33:01 PDT 2017
Hi Andrew,
> I'm trying to enable autotest so that I can easily verify changes I make to
> GDAL. I'm having difficulty as my familiarity with the python environment
> is limited. I don't think I want to install the swig bindings OVER the
> current GDAL interface code that I may have in my system python
> installation. I would think I could build the bindings, have the
> associated .so's (or .dylib's) reference the GDAL build tree and install
> the python modules/shared objects in a location I can invoke from autotest
> by setting PYTHONPATH accordingly.
> This seems difficult to accomplish given the setup so it makes me think I'm
> doing something wrong. Is there a standard (and easy) way to get tests
> going on a local GDAL build tree that I'm missing?
In each of my GDAL trees, I have in gdal root (where you invoke ./configure) a setenv.sh script
with the following content
export PATH=$PWD/apps:$PATH
export LD_LIBRARY_PATH=$PWD:$LD_LIBRARY_PATH
export GDAL_DATA=$PWD/data
export PYTHONPATH=$PWD/swig/python/build/lib.linux-x86_64-2.7
which I source. So that way I don't need to run "make install"
This is for a --without-libtool build. For a libtool build, you need to modify to
export PATH=$PWD/apps/.libs:$PATH
export LD_LIBRARY_PATH=$PWD/.libs:$LD_LIBRARY_PATH
> P.S. - It seems strange to use python as a CI interface to a C/C++
> library. Is there a reason the test harness isn't in C/C++?
Mateusz already answered on that. Writing Python tests is faster/easier than C/C++ ones.
We/I tend to limit C/C++ written tests to part of the API not available through the Python
API.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170926/51220ccb/attachment.html>
