[gdal-dev] Fillvalue set incorrectly on gdal_translate to NetCDF for Byte
Even Rouault
even.rouault at spatialys.com
Wed Sep 27 03:27:53 PDT 2017
On mercredi 27 septembre 2017 10:00:23 CEST Julian Zeidler wrote:
> Hi all,
> I noticed, what I believe is an Error when converting a Byte Image from
> geotiff to Netcdf. In the newest Gdal Version (trunk from Monday), it
> reports the correkt NoData Value (in older gdal Version i tested this
> 1.11 this was also incorrekt) but it reports the _FillValue as -1 while
> reporting that the Dataset is _Unsigned. This looks like the FillValue
> is written as a signed byte (For Na=254 it reports fillvalue=-2).
> Is this difference between noData and _FillValue intentional? And is
> there any way to "fix" the FillValue in my Netcdf ?
> I ran gdal_translate example.tif example.nc -of netCDF
> The tiff reports the (korrekt) NaValue as :
> Band 1 Block=2000x4 Type=Byte, ColorInterp=Gray
> NoData Value=255
> While in the NetCDF I get :
> Band 1 Block=2000x1 Type=Byte, ColorInterp=Undefined
> NoData Value=255
> Metadata:
> grid_mapping=transverse_mercator
> long_name=GDAL Band Number 1
> NETCDF_VARNAME=Band1
> valid_range={0,255}
> _FillValue=-1
> _Unsigned=true
Julian,
this is an artifact of the old netCDF3 format (which is the default when reating a file with
GDAL), which doesn't support unsigned byte, but signed byte. So GDAL has to use hacks to
put unsigned byte to signed byte.
It sets a Band1:_Unsigned = "true" metadata, and then on reading, it knows that it must
interpret signed as unsigned. The _FillValue=-1 just reflects that. That is what you will get if
you use the "ncdump" utility. I'm ambivalent if GDAL should "fix" it or not.
Recent versions of GDAL do fix the NoData value since that's what users should use. The
_FillValue is more an internal implementation detail.
As netCDF 4 is quite widespread now, you could also just do
gdal_translate example.tif example.nc -of netCDF -co FORMAT=NC4
and then everything will be unsigned.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170927/fde67da6/attachment.html>
