[gdal-dev] Fillvalue set incorrectly on gdal_translate to NetCDF for Byte
Julian Zeidler gdal at zeidlers.de
Wed Sep 27 05:12:25 PDT 2017
Am 27.09.2017 um 12:27 schrieb Even Rouault:
> On mercredi 27 septembre 2017 10:00:23 CEST Julian Zeidler wrote:
> > Hi all,
> > I noticed, what I believe is an Error when converting a Byte Image from
> > geotiff to Netcdf. In the newest Gdal Version (trunk from Monday),  it
> > reports the correkt NoData Value (in older gdal Version  i tested this
> > 1.11 this was also incorrekt) but it reports the _FillValue as -1 while
> > reporting that the Dataset is _Unsigned. This looks like the FillValue
> > is written as a signed byte (For Na=254 it reports fillvalue=-2).
> > Is this difference between noData and _FillValue intentional? And is
> > there any way to "fix" the FillValue in my Netcdf ?
> > I ran  gdal_translate example.tif example.nc -of netCDF
> > The tiff reports the (korrekt) NaValue as :
> > Band 1 Block=2000x4 Type=Byte, ColorInterp=Gray
> >   NoData Value=255
> > While in the NetCDF I get :
> > Band 1 Block=2000x1 Type=Byte, ColorInterp=Undefined
> >   NoData Value=255
> >   Metadata:
> >     grid_mapping=transverse_mercator
> >     long_name=GDAL Band Number 1
> >     NETCDF_VARNAME=Band1
> >     valid_range={0,255}
> >     _FillValue=-1
> >     _Unsigned=true
> Julian,
> this is an artifact of the old netCDF3 format (which is the default
> when reating a file with GDAL), which doesn't support unsigned byte,
> but signed byte. So GDAL has to use hacks to put unsigned byte to
> signed byte.
> It sets a Band1:_Unsigned = "true" metadata, and then on reading, it
> knows that it must interpret signed as unsigned. The _FillValue=-1
> just reflects that. That is what you will get if you use the "ncdump"
> utility. I'm ambivalent if GDAL should "fix" it or not.
> Recent versions of GDAL do fix the NoData value since that's what
> users should use. The _FillValue is more an internal implementation
> detail.
> As netCDF 4 is quite widespread now, you could also just do
> gdal_translate example.tif example.nc -of netCDF -co FORMAT=NC4
> and then everything will be unsigned.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Hi Even,
Thanks for the quick reply.
I was aktually running it with -co FORMAT=NC4, but on Version 2.11.3,
where there was no difference with or without this option. So i
simplified it when testing on trunk. My Bad. Will migrate to a more
recent Version.
Thanks
Julian
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170927/438aa8b0/attachment.html>
