[gdal-dev] GOES-16 Projection Issue
Even Rouault even.rouault at spatialys.com
Wed Apr 4 03:58:22 PDT 2018
On mercredi 4 avril 2018 11:13:29 CEST Simon Proud wrote:
> Hello,
> I am trying to visualise GOES-16 data, but the output projection from
> gdal_translate appears faulty.
> This is the command I use:
> gdal_translate -a_srs "+proj=geos +a=6378137. +units=m +no_defs
> +b=6356752.31414 +x_0=0.0 +y_0=0.0 +ellps=GRS80 +lon_0=-75.0
> +f=.00335281068119356027 +h=35786023. +sweep=x" -a_ullr $ulx $uly $lrx
> $lry [input_file] [output_file]
Simon,
This has been discussed recently on the list. Basically the issue is that GeoTIFF encoding has
no way to represent this projection properly.
Long version at
http://geotiff.maptools.narkive.com/3CqwNeMd/geos-projection-sweep-parameter
A potential workaround is to have a .tif + .tif.aux.xml file and forcing a baseline TIFF to be produced
In GDAL master, I've just committed a fix so that
gdal_translate input.tif output.tif -co PROFILE=BASELINE -a_srs "+proj=geos +a=6378137. +units=m +no_defs +b=6356752.31414 +x_0=0.0 +y_0=0.0 +ellps=GRS80 +lon_0=-75.0  +f=.00335281068119356027 +h=35786023. +sweep=x"
works
With currently released versions, you have to do a more convoluted approach
1) Create a baslilne TIFF file
2) Create a dummy png file (1x1) with the projection info in .aux.xml
gdal_translate -of PNG test.tif output.png -a_srs "+proj=geos +a=6378137. +units=m +no_defs +b=6356752.31414 +x_0=0.0 +y_0=0.0 +ellps=GRS80 +lon_0=-75.0  +f=.00335281068119356027 +h=35786023. +sweep=x" -srcwin 0 0 1 1
3) Rename output.png.aux.xml to output.tif.aux.xml
4) Check with "gdalinfo output.tif" that you get the right projection info
Even
http://www.spatialys.com
