[gdal-dev] scripts/setdevenv.sh
Even Rouault even.rouault at spatialys.com
Thu Apr 5 02:44:46 PDT 2018
This is something most people doing GDAL development, and not wanting to install each time they
build, have probably reinvented by themselves, so now master has a scripts/setdevenv.sh that
you can source to define PATH, LD_LIBRARY_PATH, GDAL_DATA and PYTHONPATH to point to the
non-installed directories.
Referenced in https://github.com/OSGeo/gdal/blob/master/CONTRIBUTING.md
Only tested on Linux
$ . scripts/setdevenv.sh
Setting PATH=/home/even/gdal/git/gdal/gdal/apps:/home/even/gdal/git/gdal/gdal/apps/.libs:/home/even/bin:/home/even/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Setting LD_LIBRARY_PATH=/home/even/gdal/git/gdal/gdal:/home/even/gdal/git/gdal/gdal/.libs:
Setting GDAL_DATA=/home/even/gdal/git/gdal/gdal/data
Setting PYTHONPATH=/home/even/gdal/git/gdal/gdal/swig/python/build/lib.linux-x86_64-2.7:
Even
http://www.spatialys.com
