[gdal-dev] Large number of "Unable to translate coordinate system" in epsg file
Kristian Evers kreve at sdfe.dk
Tue Apr 17 04:52:47 PDT 2018
I've added a ticket for the addition for the Michigan LCC: https://github.com/OSGeo/proj.4/issues/940
It is a rather trivial change so a good issue for a first time PROJ contributor.
/Kristian
-----Oprindelig meddelelse-----
Fra: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] På vegne af Even Rouault
Sendt: 17. april 2018 10:49
Til: gdal-dev at lists.osgeo.org
Emne: Re: [gdal-dev] Large number of "Unable to translate coordinate system" in epsg file
On lundi 16 avril 2018 10:46:18 CEST Roger André wrote:
> Hi All,
> Slightly off-topic question, but I'm curious why I'm seeing so many entries
> that look like this in my epsg file:
> # NAD27 / Michigan North
> # Unable to translate coordinate system EPSG:6200 into PROJ.4 format.
> Is this normal, or the sign of a flawed install of dependencies, or
> something else?
Yes this is "normal".
EPSG:6200 / "NAD27 / Michigan North" uses a LCC_2SP(Michigan) projection
(EPSG:1051) which is not supported by GDAL / proj :
http://lists.maptools.org/pipermail/proj/2015-April/007108.html
Even
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
