[gdal-dev] Large number of "Unable to translate coordinate system" in epsg file
Roger André
randre at gmail.com
Tue Apr 17 06:44:42 PDT 2018
OK, thank you.
On Tue, Apr 17, 2018, 4:53 AM Kristian Evers <kreve at sdfe.dk> wrote:
> I've added a ticket for the addition for the Michigan LCC:
> https://github.com/OSGeo/proj.4/issues/940
> It is a rather trivial change so a good issue for a first time PROJ
> contributor.
> /Kristian
> -----Oprindelig meddelelse-----
> Fra: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] På vegne af Even
> Rouault
> Sendt: 17. april 2018 10:49
> Til: gdal-dev at lists.osgeo.org
> Emne: Re: [gdal-dev] Large number of "Unable to translate coordinate
> On lundi 16 avril 2018 10:46:18 CEST Roger André wrote:
> > Hi All,
> > Slightly off-topic question, but I'm curious why I'm seeing so many
> entries
> > that look like this in my epsg file:
> > # NAD27 / Michigan North
> > # Unable to translate coordinate system EPSG:6200 into PROJ.4 format.
> > Is this normal, or the sign of a flawed install of dependencies, or
> > something else?
> Yes this is "normal".
> EPSG:6200 / "NAD27 / Michigan North" uses a LCC_2SP(Michigan) projection
> (EPSG:1051) which is not supported by GDAL / proj :
> http://lists.maptools.org/pipermail/proj/2015-April/007108.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180417/156a8f8b/attachment.html>
