[gdal-dev] ogr2ogr JSON -> Shapefile Failing
Even Rouault
even.rouault at spatialys.com
Wed Apr 18 13:34:18 PDT 2018
On mercredi 18 avril 2018 20:00:40 CEST Cechini, Matthew F. (GSFC-423.0)
[Science Systems & Applications, Inc.] wrote:
> All,
> Once upon a time (GDAL 1.x) I was able to convert the following JSON to
> Shapefile without errors. However with GDAL 2.x I am not. Any assistance
> you can provide is welcome. I’m running a simple ` ogr2ogr -f "ESRI
> Shapefile" -preserve_fid <out> <in>` command.
Add " -fieldTypeToString Time" to force the conversion of time fields as
strings.
Even
http://www.spatialys.com
