[gdal-dev] ogr2ogr JSON -> Shapefile Failing
Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
matthew.f.cechini at nasa.gov
Wed Apr 18 13:41:05 PDT 2018
Great, that worked. Now to figure out how to solve the "Warning 1: Feature id not preserved" error. I suspect if I dig long enough in google I'll find the key, but am hoping someone will see this and make my life easy.
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
On 4/18/18, 4:34 PM, "Even Rouault" <even.rouault at spatialys.com> wrote:
On mercredi 18 avril 2018 20:00:40 CEST Cechini, Matthew F. (GSFC-423.0)
[Science Systems & Applications, Inc.] wrote:
> All,
> Once upon a time (GDAL 1.x) I was able to convert the following JSON to
> Shapefile without errors. However with GDAL 2.x I am not. Any assistance
> you can provide is welcome. I’m running a simple ` ogr2ogr -f "ESRI
> Shapefile" -preserve_fid <out> <in>` command.
Add " -fieldTypeToString Time" to force the conversion of time fields as
strings.
Even
http://www.spatialys.com
