[gdal-dev] Quete_string_fields creation option for CSV
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Apr 19 04:27:55 PDT 2018
Even Rouault wrote:
Re: [gdal-dev] Quete_string_fields creation option for CSV
> Actually I've reworked this to be
> STRING_QUOTING=IF_NEEDED/IF_AMBIGUOUS/ALWAYS (Starting with GDAL 2.3): whether to double-quote strings. IF_AMBIGUOUS means that string values that look like numbers will be quoted (it also implies IF_NEEDED). Defaults to IF_AMBIGUOUS (behaviour in older versions was IF_NEEDED)
Feels like a good set of options and I will probably enjoy IF_AMBIGUOUS myself sooner or later because we have IDs with leading zeroes here and there.
-Jukka-
